What happen to frame padding?
  • What happen to frame padding?
    I am running V-Ray batch with the latest nightly build and the script editor says:
    lookdev_v001_env_bg.0006.exr
    the renders say something else:
    lookdev_v001_env_bg0006.exr
    Is there a quick fix to correctly place the period before the frame ext?
    Isn't it the same problem as this one ?
    http://www.chaosgroup.com/forums/vbu...e-name-changes
      That sucks. I never had that issue until I started using Maya batch to render. So there won't be a fix because people are putting periods into a script to make up for the error?
      How about having it fixed, and everyone can delete the band aid script.
        Hey Scott... you ever find the band aid for this?
          i have a solution for u people that works, and u dont have to pay me, hahaha
          in the File Name Prefix box, if ur image name is => lookdev_v001_env_bg
          just add the dot at the end
          like this ->lookdev_v001_env_bg.
          i know that maya will show two dots lookdev_v001_env_bg..exr or something like that, but dont worry when u render a seq everything will be fine
          cheers
