Nightly build file read problem
  • Nightly build file read problem
    When creating a file read node with the latest nightly build, there are some serious issues where it freezes up the interface when loading a texture, or changing filter mode.
    It makes loading textures impossible to work with. Is there a workaround for this at the moment?
    I think this might be from a windows permission issue.
      I don't think anything has changed in that regard in the nightly builds...
        Yeah, it's strange.. I am having it happen again.. I think either my hard drive is going to fail, or its something with V-Ray. It doesn't happen when I unload the V-Ray plugin. I will see if it happens with stable build.
          I'm emailing a link to the video recording of it..
          Thanks.
            Might be worth trying the env variable fix described here
            http://www.chaosgroup.com/forums/vbu...er-frozen-at-0
            One of the guys at work was having something similar to you today, and it seemed to go away with this fix. (But there were other things going on too, so it may have been something else - easy to try though)
              Thanks for the link, but Maya comes back and I don't have to kill it.. There's just a really long delay.. Stable build works.
