Hi All,
I keep having a recurring issue when changing the resolution width/height in the VRay Common tab. If I change the either the width or height values Maya seems to hang / lag for ages (like minutes). I usually am forced to restart Maya to save time. I noticed that Maya uses 1 full processing core for quite a while before the system/program finally catches up. This issue gets worse as the scene poly count gets higher.
Has anyone else experienced the same issue?
Cheers, Pete
System Specs:
Mac Pro 2 x 2.66 GHz 6 Core Intel Xeon / SD 512mb / 24gb Ram / Mac OS 10.6.8
Nvidia Quadro 4000 for Mac
Maya 2012 (Hotfix 3-64bit) Vray 2.0
Cheers, Pete
System Specs:
