// Error: Exception [module=1]
  • // Error: Exception [module=1]
    So I have a scene. Its got a couple different cameras. I have a closeup camera and then a wider camera. The closeup camera renders fine but when I pull out for the wide shot it gives me this error:
    // Error: Exception [module=1] : Rendering region (704,704)-(768,720) //
    // Error: There was a fatal error rendering the scene. //
    No matter what I do it seems to give me this error every time. I don't know why. Any suggestions? Have you experienced this before?
    Thanks!
    Hello,
    Do you use Image Plane for the camera? Because I got a similar Error message when I used it.
    If you are using Image Plane please check this thread - http://www.chaosgroup.com/forums/vbu...ht=image+plane
    Best Regards,
      I've got the same here...
      Figured out that the point is the image plane, without no errors...
      With a fresh image plane it works first, but if I put a texture input gamma attribute on it it crashes....
      Would be nice if that is fixed soon.
      I get the Module 1 error if GI is turned off
      and a moule 2 error (irradiance map thread) if GI is turned on
      Nightly Build from 30 Nov 2011
      Cheers
      Dominik
      Dominik Markota | Head of CGI | Senior Shading & Lighting TD @ Serviceplan MAKE
        Thanks for the pointer; we can reproduce the issue and we are looking into it.
          Hey sersia and Mr. Hoo you are correct! I was using an image plane. And I was using a nightly build from late November. That seems to be the problem! Thanks so much for your expertice
            This should be fixed in the next nightly.
            V-Ray/PhoenixFD for Maya developer
              Thx a lot vlado!!! You are the best!
              Should we meet anywhere anytime, I'll pay the beer!
              Cheers!
                Hi Vlado,
                is there any chance to see this fixed in a nightly for snow leopard?
                Because the same error drove me mad last night, hehe
                Cheers!
                  It should be there already.
