vrmesh vertex color info?? urgent!
  • vrmesh vertex color info?? urgent!
    Hi vlado, i have a probl with vertex color (i think)
    i have an obj with vertex color set and i have converted to vrmesh (with vertex color export check), when i import proxy into maya i dont see the vertex color info?
    how can i see it? and where is that info located?
    cheers
    Vlado did u have time to take a look this probl? Or anyone?
    How to read the vertex color info from vrmesh???
    cheers
      What exactly are you trying to do with the vertex colors? In Maya, you can use VRayVertexColors texture. Set the type to "Set name" and enter the set name bellow.
      V-Ray/PhoenixFD for Maya developer
        hi ivanov, i know that, i do have vertex color in maya with regular mesh, but when i export that mesh as a proxy (with vertex color export option) and when i import that vrmesh into maya i dont have any vertex info any more? so how to get back the vertex color info from vrmesh?
        cheers
          This works fine for me on a simple test; can you get me more specific reproduction steps?
            hi vlado,
            ok here is how i did it...
            1. create sphere
            2. add color-create empty color set
            3. paint vertex color
            4. create vraymtl & VRayVertexColors
            5. connect VRayVertexColors-> vraymtl color & apply to sphere
            6. connect sphere mesh.color set 0 -> VRayVertexColors.color set
            7. (render test) just to make sure that everything is ok
            8. export sphere as vray proxy with export color vertex option ON
            9. New scene
            10. import proxy
            and what now?
            cheers
              i manage to found it
              solution is to turn on the Set Index and set to 1
              sorry for trouble, but i have another question according to this , as u all may already saw im using naiad, and i was converting emp files to vrmesh, but i wasnt able to transfer the point color from bgeo -> vrmesh with ply2vrmesh converter
              so could u plz vlado if u have time check this, i could send u a sample bgeo obj for test
              cheers
                Originally posted by bazuka View Post
                and what now?
                Apply the VRayMtl material to the proxy; assign a VRayVertexColors texture to the slot you want, set the "type" to "Set Name" and in the text field below type the name of your color set (by default "colorSet" without the quotes). That's all.
                  I don't think we do the colors right now from .bgeo files... if you have some examples, please send it over and we'll try to figure out a way to transfer them.
                    great here it is
                    https://rapidshare.com/files/4194746...Ocean.0001.rar
                    and this is how this thing looks like
                    i was planing to make emp->vrmesh if u dont have that in ur "to do list"
                      Hi vlado, could u plz let me know soon as u have anything on this probl, i mean the point color from bgeo?
                      cheers
                        Hi Bazuka,
                        The color set support should be present in the next nightly build.
                        Please test it and report if there are any problems with it.
                        I've added support for both .geo and .bgeo files.
                        Teodor
                        V-Ray developer
                          Thx Teodor for quick reply, let me know if u have time coz i have a lots of req in this moment
                          as i said before i need a lots of info from naiad emp mesh that is transfer to bgeo->vrmesh but im loosing those infos in conversion process...
                          best regards
                            Great news!
                            OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
                            • #15
                              For the moment we convert all the vector and 3-float vertex attributes from the .geo/.bgeo file to color sets, so if the information that you need is stored in such channels, it will automatically come through.
