Exit code 0 after V-Ray error
  • Exit code 0 after V-Ray error
    Maya version: Maya 2011 x64 Subscription Advantage Pack, Cut Number 201009100611
    V-Ray version: V-Ray for Maya version 2.00.04 from Apr 28 2011, 02:23:27. V-Ray: V-Ray core version is 2.00.01
    Code:
    V-Ray: Starting render
    [2011/Dec/21|14:26:49] V-Ray: Loading plugins from "/usr/autodesk/maya2011.5-x64/vray/vrayplugins/libvray_*.so"
    [2011/Dec/21|14:26:51] V-Ray: 101 plugin(s) loaded successfully
    [2011/Dec/21|14:26:51] V-Ray: Finished loading plugins.
    [2011/Dec/21|14:26:51] V-Ray: Exporting scene to V-Ray.
    [2011/Dec/21|14:26:51] V-Ray: Parsing light links time  0h  0m  0.0s (0.0 s)
    [2011/Dec/21|14:26:51] V-Ray: Translating scene geometry for V-Ray
    [2011/Dec/21|14:26:51] V-Ray:  (Estimated time remaining:  0h  0m  0.0s): 80 % completed
    [2011/Dec/21|14:26:51] V-Ray: Total time translating scene for V-Ray  0h  0m  0.2s (0.2 s)
    [2011/Dec/21|14:26:51] V-Ray: Rendering.
    [2011/Dec/21|14:26:51] V-Ray: Pre-render export.
    [2011/Dec/21|14:26:53] V-Ray: Pre-render export done.
    [2011/Dec/21|14:26:53] V-Ray: Rendering frames.
    [2011/Dec/21|14:26:53] V-Ray: Updating frame at time 1017.00
    [2011/Dec/21|14:26:53] V-Ray: Total time updating frame  0h  0m  0.0s (0.0 s)
    [2011/Dec/21|14:26:53] V-Ray: Updating frame at time 1017.25
    [2011/Dec/21|14:26:53] V-Ray: Updating frame at time 1017.75
    [2011/Dec/21|14:26:53] V-Ray: Preparing renderer...
    [2011/Dec/21|14:26:53] V-Ray: Preparing scene for rendering...
    [2011/Dec/21|14:26:53] V-Ray: Preparing scene for frame...
    [2011/Dec/21|14:26:53] V-Ray:  (Estimated time remaining:  0h  0m  0.0s): 21 % completed
    [2011/Dec/21|14:26:54] V-Ray: Bitmap file "/flock/proj/kontiki/shottree/095/060/3d/maya/textures/SKIESV2_08ST3_060_v001.hdr" loaded.
    [2011/Dec/21|14:26:55] V-Ray error: There was a fatal error rendering the scene.
    Error: There was a fatal error rendering the scene.
    [2011/Dec/21|14:26:55] V-Ray: Render complete
    [2011/Dec/21|14:26:55] V-Ray: ========================
    [2011/Dec/21|14:26:55] V-Ray: Clearing exporter memory...
    [2011/Dec/21|14:26:55] V-Ray: Total time clearing exporter memory  0h  0m  0.0s (0.0 s)
    This render exits with a 0.
    Best regards
    Thomas
    Thanks for the pointer; I thought we always set the exit code on error for batch mode, but I'll check again.
      Code:
      Best regards
      Thomas
      Hi Vlado,
      got same exact error many times with random scenes no way to reproduce. They only way to fix this is going to a previous version of the scene or create a fresh one a re-import things.
      I know you have been asked this 1000 times but when an big update is coming for Vray2 Maya ?
      Thanks,
      Alex.
        Originally posted by alexitoland View Post
        Hi Vlado,
        Thanks,
        Alex.
        Me ,again I hope this is heplful these are the main 3 areas that we got lots for problems:
        1- Fatal errors like the one posted.
        2- Vray RT CPU , we don use GPU crashes constantly on any production scene, its almost impossible to work with it at all which is a huge disadvantage,
        3 - Vray FBV disappears again randomly.
        This is a result of using Vrat v2.004 with latest Maya 2012 on several brand new Win7 24cores 24GB machines with Quadro 4000.
        Thanks,
        Alex.
          Can you check this again with the latest nightly builds? If you don't have access to the nightlies, you can email us to vraymaya@chaosgroup.com It would also be very helpful if you can get us a crashing scene.
