Time line bar run before Renders
  • Time line bar run before Renders
    I am using V-Ray for Maya 2.25.01.
    When I am try render the time line bar go to frame zero run all frames till reach the frame that is choose and render the frame inside of Renderview.
    Now I can“t use bookmark camera because of this problem.
    I never had this problem before in other version, whats happening?
    I also noticed that. When I change the camera position to check some detail and am within two keyframes, maya resets that cam to the according position. I'm not sure, if that behavior is new or if I didn't notice it till now..any info about that?
    best regards,
    sacha
      Hm, it's because of the export of some parameters. We will try to export them without moving the time.
        hmm.. after taking a break I decided to restart using the latest release (2.30.01) - That issue still exists. Right? Does it also exist in the nightlies? Don't want to switch back an forth again just to look at it.
        best regards,
        sacha
          Get me a scene that I can test with and I'll tell you I think I did not merge the fix in the 2.30 build yet.
            If you are using physical camera, it may be related to that. Vlado any chance to get that into a stable branch?
            Dmitry Vinnik
            Silhouette Images Inc.
            ShowReel:
              Yes, will do that.
                Thanks Dmitry.. Yes I'm using the physical camera and I have to
                And vlado - to cut the scene down to a reasonable filesize will take the same time as installing the nightlies =) So I'll install the latest nightly to see, what it does for me =)
                anyway thanks guys..
                best regards,
                sacha
