Vray FB crash after rendering
  • Vray FB crash after rendering
    there seems to be a bug that causes a crash after the rendering is done. I am not sure if it is a Vray frame buffer issue or Maya related.
    You can reproduce it as follows:
    1. create a simple scene with a poly sphere and a directional light
    2. check "Use V-Ray VFB" in Render Globals
    3. open Maya Render View and right click on the first icon on the left (Redo previous render) and choose persp camera
    4. VFB will open and render the image. After the rendering is done Maya freezes.
    To circumvent this, you can either make a snapshot of the desired camera and then click the render button or choose the camera in the render menu (Render -> Render -> persp).
    Maya 2012 x64 SAP SP1
    Vray 2.25.01 19212
    Cheers,
    Markus
    So it does Many thanks for the reproduction steps, I've been trying to reproduce this here for a long time. Looking into it now.
      So this should be solved now for revision 19735 and later - if you can check and confirm it would be great.
        Everything looks fine. No more crashes with the new build. Thanks Vlado!
        Regards,
        Markus
          Great, thanks!
