Dear Vlado
We have running vray2.00.04_ADV for maya2011 on windows Vista64. We plan use new version of Vray next week
Ok. We have problems with file textures paths (maya file node) that contain enviroiment variables e.g.
$SHOW/work/oprzybyszewski/maya/sourceimages/3de_telefony_seq0010_shot0020_c5.render/EkranNokia.tga
When it comes to rendering we got following warning.
// Warning: Bitmap file "$SHOW/work/oprzybyszewski/maya/sourceimages/3de_telefony_seq0010_shot0020_c5.render/EkranNokia.tga" failed to load: [LoadImageFile] Failed to open file: no such file //
SHOW environment variable is set after loading Maya, so it's visible only in Maya environment. We set SHOW variable using following python code:
os.environ['SHOW']=our_path
Script that contain this code is running during loading Maya using following code:
maya -script startupScript
In Maya script editor os.getenv('SHOW') command gives me correct result.
Other renderes like MentalRay or Software renderer in Maya don't have problems with reading this file ( they can render properly this file and We can see this file in viewport).
Do You have any idea what is happened?
Regards Olaf
Regards Olaf
