I have a question for V-Ray Physical Camera.
1. Change the current frame through time slider to 1000.
2. Hit the Render Button, then it is instantly render the current frame. There is no problem if I don't use V-Ray Physical Camera.
3. Turn on V-Ray Physical Camera.
4. Hit the Render Button again at 1000 frame, then the current frame move to 0 frame or 1 frame and play to 1000 frame first and then start rendering.
Is it normal? I know it is quite moving fast from 0 frame to current frame before starting rendering with V-Ray Physical Camera but it is quite noise if I need to test render at the point of big current frame.
Thank you for your help in advance.
Best Regards,
Sangho Jung.
Best Regards,
Sangho Jung.
