PhoenixFD Beta install problem
  • PhoenixFD Beta install problem
    The plugins is not loading in 2012 64 bit. Running VRAY 2.25.01/ API version 201200.
    Getting an error message:
    // Error: Unable to dynamically load : C:/aw/Maya2012/vray/plug-ins/phoenixfd.mll
    The specified procedure could not be found.
    // Error: The specified procedure could not be found.
    (phoenixfd) //
    Vadim
    VFX/CG Supervisor
    Curious Pictures
    I gotta say i just faced with the same probl here
      PhoenixFD is not compatible with some nightly builds of VRay. If you don't use the official VRay versions, install some recent nightly build (after March 10.)
      V-Ray/PhoenixFD for Maya developer
        Thanks. I will check it against the build mentioned.
        Vadim
        VFX/CG Supervisor
        Curious Pictures
