Projection mapping gets low res when rendering
  • Projection mapping gets low res when rendering
    I have an image sequence that I want to project on a plane through a camera. However, when I render through vray (with more or less default settings) the projected image gets a resolution of what looks like 256x256 or something.
    When I render through software render it looks ok, the same when looking at it in the viewport. I dont know what it could be. The scene is very basic, just a tracked camera, a plane with a projection with fit type at cam res/horizontal, and default render settings. Any ideas?
    edit: ok, solved it. Used a vray texture filter attribute on the file node and set filtering to nearest.
    I would still be curious to take a look at the scene if you have the time to send it to us at vraymaya@chaosgroup.com
      Sure, I´ll make a zip tomorrow.
