SDK driven shading attribute issue
  • SDK driven shading attribute issue
    VRay seems to have a viewport update problem when a shader attribute, i.e. color, is remotely changed with SDK.
    I have set up a sample scene where an enum attribute is supposed to let the user switch between several pre-defined color setups. The first sphere has a regular maya material and the other a vray material. The enum attribute controls the color of both shaders via SDK.
    When switching between the colors the lambert updates just fine and presents the new color in the viewport, the vray shaded sphere doesn't show a change - until rendered. In the hypershade the materials update just fine during the switching.
    Any ideas if this is supposed to be this way or what could be wrong here?
    Thanks, Ingo
    brave rabbit | Mac Pro 3.5 GHz 6 Core | ATI FirePro D700 | 32 GB RAM | OS X 10.13.3
    Can you tell me how exactly you are changing the colors?
      Hi Vlado,
      thanks for replying.
      I've tried to attach a zip file to the post but the thing didn't let me Here's the link the an external file which is the sample scene I mentioned.
      http://bit.ly/Jp3uAB
      It's just a simple SDK from a transform nodes enum attribute to the shader color.
      Thanks, Ingo
        Fixed with revision 21327
        V-Ray/PhoenixFD for Maya developer
          Thanks for the info. Looking forward to the next release.
