Shadow colors using Maya spotlights (bug)
  • Shadow colors using Maya spotlights (bug)
    I'm trying to use colored shadows for a shadow ID pass using the matteShadow render element, for example a spotlight with a red shadow (RGB Shadow color:0,1,1).
    If the spotlight is set to a luminance equal to 1, everything renders as expected. If the luminance is set to >1, the shadow color no longer remains red, as all the channels in the matteShadow are increased additively by the degree of luminance >1. For example, if my light intensity is set to 2.0, the shadow color will be: 2,1,1.
    Hm, I'm not getting quite the same effect - for me the matteShadow element never goes beyond (1,1,1). It is calculated as (white-shadowedColor/unshadowedColor). As you increase the light intensity, the unshadowedColor is increased proportionally, but the shadowedColor stays the same - the final effect is that the result is pushed towards white.
      Well I've built a test scene that replicates the problem, I'm emailing it to you, as I'm not sure how to attach files in these forums. Build is: 2.10.01, revision 20096
      // Edit: nevermind, I figured it out
