Maya Fluid assigned to color in shader
  • Maya Fluid assigned to color in shader
    Hi All,
    In maya when I create a fluid I can connect the out color of that fluid to a shader and render that fluid as a "projected" texture.
    When trying to do that in VRay it doesn't work, neither on a lambert or a VRay_mtl, and multiple attempts to "convert" the output
    through a node that VRay usually works with failed as well.
    I have attached a scene file that illustrates the issue (the fluid is hidden on a layer)
    Any help would be greatly appreciated!
    Thanks!
    test_scene.zip (Please rename to ".ma")
    Sorry for the late reply; we don't support this feature for the moment - I'll make a note to add it.
      Ok! Thanks for the reply, I'll guess we'll have to wait
