strange Shave&Haircut crash : density map + multistrand
  • strange Shave&Haircut crash : density map + multistrand
    Hi there,
    I'm having troubles with the latest versions of vray / shave&haircut plugins.
    os: Mac OSX 10.6.8
    maya: 2012 sp1
    vray: 2.20.01 (core 2.00.01 ?)
    shave : 6.0v71
    When using "some density maps" with multistrands, maya crashes at render time ... it won't occur without multistrand, or with hand drawn black&white map.
    Here is my test :
    - load vray then shave plugins
    - create a sphere with default afro hair
    - select vray renderer
    - set density map with a simple file
    - set multi strand count (say 5)
    - click render and ... beng !
    Any tip or trick to debug things would be greatly appreciated, I can't find a clue in the stack trace ! I cannot attach my tif files, but would be happy to send example textures by any means.
    Code:
    [2012/Aug/31|15:49:04] V-Ray: V-Ray for Maya version 2.20.01 from Feb  1 2012, 11:20:29
    [2012/Aug/31|15:49:04] V-Ray: V-Ray core version is 2.00.01
    libpng warning: Ignoring attempt to set cHRM RGB triangle with zero area
    shaveVrayCmd::attachShaderTo(...)
    shaveVrayCmd::attachShaderTo(...) -- OK
    V-Ray: Starting render
    [2012/Aug/31|15:50:55] V-Ray: Loading plugins from "/Network/Applications/Autodesk/maya2012sp1_test/Maya.app/Contents/vray_test/vrayplugins/libvray_*.so"
    [2012/Aug/31|15:51:01] V-Ray: 107 plugin(s) loaded successfully
    [2012/Aug/31|15:51:01] V-Ray: Finished loading plugins.
    [2012/Aug/31|15:51:01] V-Ray: Exporting scene to V-Ray.
    [2012/Aug/31|15:51:01] V-Ray: Parsing light links time  0h  0m  0.0s (0.0 s)
    [2012/Aug/31|15:51:01] V-Ray: Translating scene geometry for V-Ray
    shaveVrayNode::createVRayPlugin(...)
    SHAVE: Shave and A Haircut for V-Ray (v1.0.15)
    SHAVE: Shave core (6.0v33)
    SHAVE: (c) 2010-2012 Joe Alter Inc.
    [2012/Aug/31|15:51:01] V-Ray: Total time translating scene for V-Ray  0h  0m  0.1s (0.1 s)
    [2012/Aug/31|15:51:01] V-Ray: Rendering.
    [2012/Aug/31|15:51:01] V-Ray: Rendering frames.
    Stack trace:
      4   libShave.dylib                      0x000000016c4b00b0 SHAVEexport_archive + 10512
      5   libShave.dylib                      0x000000016c41931c shaveVrayRenderer::render(float, shaveConstant::ShutterState, MDagPath const&) + 76
      6   libShave.dylib                      0x000000016c3d62b7 shaveRenderer::doShutter(MTime const&, shaveConstant::ShutterState) + 215
      7   libShave.dylib                      0x000000016c41a4cf shaveVrayRenderer::vrayKeyframeCallback() + 1055
      8   libShave.dylib                      0x000000016c3c9afd shaveRenderCmd::doIt(MArgList const&) + 2989
      9   libOpenMaya.dylib                   0x000000015f9c07e9 THcommandObject::doIt(TargList&) + 137
      10  libCommandEngine.dylib              0x0000000100b478bd TmetaCommand::doCommand(TargList&) + 93
      11  libCommandEngine.dylib              0x0000000100b47b67 Mel_Command_Dispatch(SphNode*) + 279
      12  libCommandEngine.dylib              0x0000000100b93bf9 f_function_entry_node + 1097
      13  libCommandEngine.dylib              0x0000000100b6b1b9 node_exec + 89
      14  libCommandEngine.dylib              0x0000000100b6b27d sophia_call_executable + 109
      15  libCommandEngine.dylib              0x0000000100b8f1bc SophiaExecutable::evaluate(void*) + 124
      16  libCommandEngine.dylib              0x0000000100b4ec55 TcommandEngine::executeCommand(Tstring const&, bool, bool, TmelCmdResult*, unsigned int) + 901
      17  libOpenMaya.dylib                   0x000000015f9ed821 MGlobal::executeCommand(MString const&, bool, bool) + 113
      18  vrayformaya.bundle                  0x000000016ab2e23f VRayMayaRenderer::callPreKeyframeMel() + 79
      19  vrayformaya.bundle                  0x000000016ab31a8c VRayMayaRenderer::advanceTimeAndCreateKeyframes() + 1388
      20  vrayformaya.bundle                  0x000000016ab31f7b VRayMayaRenderer::renderSequence() + 923
      21  vrayformaya.bundle                  0x000000016ab33928 VRayMayaRenderer::renderImpl() + 296
      22  vrayformaya.bundle                  0x000000016ab36961 VRayMayaRenderer::render(VUtils::VRayVFB*, MayaRenderParams const&) + 337
      23  vrayformaya.bundle                  0x000000016ad38f39 VRendCmd::doIt(MArgList const&) + 3113
      24  libOpenMaya.dylib                   0x000000015f9c07e9 THcommandObject::doIt(TargList&) + 137
      25  libCommandEngine.dylib              0x0000000100b478bd TmetaCommand::doCommand(TargList&) + 93
      26  libCommandEngine.dylib              0x0000000100b46e86 Mel_Command_Dispatch_old(SphNode*) + 278
      27  libCommandEngine.dylib              0x0000000100b93bf9 f_function_entry_node + 1097
      28  libCommandEngine.dylib              0x0000000100b6b1b9 node_exec + 89
      29  libCommandEngine.dylib              0x0000000100b6b27d sophia_call_executable + 109
      30  libCommandEngine.dylib              0x0000000100b8f1bc SophiaExecutable::evaluate(void*) + 124
      31  libCommandEngine.dylib              0x0000000100b4d8e5 TcommandEngine::executeCommand(SophiaExecutable*, void*) + 197
      32  libExtensionLayer.dylib             0x0000000101345ee9 TelfEvalCmd::doCommand(TargList&) + 89
      33  libCommandEngine.dylib              0x0000000100b47b67 Mel_Command_Dispatch(SphNode*) + 279
    Fatal Error. Attempting to save in /var/folders/+J/+Jn4aGPjFL8qFN8cnHBAPU++-1U/-Tmp-/nephilim.20120831.1551.maWriting crash report in /var/folders/+J/+Jn4aGPjFL8qFN8cnHBAPU++-1U/-Tmp-/nephilim.20120831.1551.crash
    Terminated
    Note that the shave plugin is still reporting as 6.0v33 version, I had to change shaveVersion.mel to load the plugin, and tried to mail Joe about this matter but no answer till now ...
    Tonio
    Thanks, we'll check it out, but just to be on the safe side, can you send us a scene for this to vraymaya@chaosgroup.com?
      Hi Vlado,
      I just sent an example scene, with a simple sphere, hairs and two texture files (brokenTex and workinTex), should be pretty easy to test things. I'm not sure it's a real issue, since we do have a complex environment with various maya, vray and shave versions in production ... I hope it's not related to some dyld_library_path misconfiguration etc.
      Thanks for your kind help, as ever, greatly appreciated.
      Tonio
