-percentRes Render Flag...
  • -percentRes Render Flag...
    Hi there,
    i really miss a Render Flag to testrender an bunch of scenes at only a certain percentage of the intended render resolution.
    Let's say i have a couple of scenes i want to preview via Batchrender at 5%. In MentalRay this would be accomplished with the -percentRes flag. Is there any way to do this in VRay? Just decreasing the resolution won't do the trick because often you want to render only a region which unfortunately needs to be defined in pixel values.
    Wouldn't it be better to measure render regions in resolution independend values, let's say from 0 to 1, left to right/top to bottom?
    best regards,
    Rasmus
    Thanks for the pointer; will add this as a feature request. However I'm not sure what you mean by
      Hi Vlado,
      I would recommend to define render regions in percent rather than absolute pixel values. By 0 to 1 I basically meant to work with values between 0% to 100% for the left/right/bottom/top margins. Expressing the render region in % would make it possible to keep a region no matter how the render resolution is changed.
      e.g. a simple example would be a region of 0,23 / 0,77 / 0.2 / 1 (left, right, bottom, top)
      All values are directly related to the image width and height, so the region stays the same, no matter if it is a 800x600 or 8000 x 6000
      This way it would also be easy to render a 5% preview without having to calculate new render region borders.
        Ah, I see. Well it's too late to change that now, but I guess V-Ray will scale the region internally anyways.
          I'm looking forward to that =)
          thx in advance!
          -Rasmus
