shave network path with vray/maya
  • shave network path with vray/maya
    We have set the VRAY_PLUGINS_X64 //network/vray/vrayplugins
    and placed Shave dlls in the folder
    Vray does not seem to recognize these network plugins
    The same plugins work when placed locally at
    C://ProgramFIles/Maya2012...
    Any suggestions?
    Which OS is this?
      Sorry, stupid question, of course it's Windows. Which V-Ray version though? I know we had this issue before, but it was fixed at some point.
        Try doing this:
        :: Declare vray build version
        SET VRAY_ROOT=Z:\_image\pipeline\maya2012\vray\vray_22 501_22367
        :: Declare shave build verion Shave v6
        SET SHAVE_ROOT=Z:\_image\pipeline\maya2012\shave\shave _v6.0v71
        :: Declare vray plugin paths
        SET VRAY_FOR_MAYA2012_PLUGINS_x64=%VRAY_ROOT%/vrayplugins;%SHAVE_ROOT%/vrayplugins
        SET VRAY_FOR_MAYA_SHADERS=%VRAY_ROOT%/shaders;%SHAVE_ROOT%/shaveHair
        SET VRAY_PLUGINS_x64=%VRAY_ROOT%/vrayplugins;%SHAVE_ROOT%/vrayplugins
        :: Declare system paths
        SET PATH=%VRAY_ROOT%/mayadll;%VRAY_ROOT%/bin;%SHAVE_ROOT%/mayadll;%SHAVE_ROOT%/plug-ins;%PATH%
        Also you will need to add the scripts and icons to appropriate paths, but this above should load regular shave/vray plugins. You do not need to place all plugins to vrayplugin folder, rather specify their locations separatly.
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
