Serious bug : animated focal doesn't work...
  • Serious bug : animated focal doesn't work...
    Like the title say, if you animate the focal of a camera, Vray will not render the animated focal.
    All my render is wrong.
    V-Ray: V-Ray for Maya version 2.25.01, revision 22344 from Sep 2 2012, 01:36:01, Maya 2011, win64.
    What is the solution, without to change the Vray build ?
    Thanks
    Edit : ok, add a physical camera, disable exposure correction, and it works. The problem is i loose some render time.
    I think you have to correct this please.
    Thanks.
    www.deex.info
    Thanks for the pointer; will look into it.
      It looks like, when you have animated focal with physical camera, the meta data of the exr is wrong also.
      Thank you.
      www.deex.info
        Will look at that too...
          We animated the focal length as well in some shots some time ago.
          The animation worked, but when we sent out the job onto our farm (Deadline Renderfarm) there was a problem when the task size was larger than one frame per task.
          The rendered animation was stuttering as if the evaluation of the focal length was different on every machine.
          After we reduced the task size to one frame per task it worked as intended (on farm with different machines), but we didn“t use the physical camera.
            Just to let you know that this was fixed.
            Best,
            Emil
            V-Ray for Maya developer
