VRay alwasy steps 1 frame forward when velocity renderelement is enabled
  • VRay alwasy steps 1 frame forward when velocity renderelement is enabled
    Hi guys,
    just a minor bug report here...when i render a frame inside maya and have velocity enabled then vray steps forward one frame while exporting and does not step back to the frame it was before when render is finished...can u check if this is a bug please?
    cheers
    Oliver
    OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
    Hi ultrasonic,
    This seems to be working fine on our end. Could you tell us a bit more about the scene, like for example are you using particles/instancer or something of the sort? And what Maya/V-Ray versions is your problem occurring with?
    yolov
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Hi yolov,
      sorry for posting this as a bug without a simple testscene....it seems to work with just a sphere...i need to investigate in our production scenes....haven't found the prob yet....will let you know asap
        OK. Waiting for more info and/or a scene then
        yolov
        Alex Yolov
        Product Manager
        www.chaos.com
          I think this only happens if you cancel the preview render before the whole image is finished. Have to test it some time.
          http://www.andreas-reimer.de
          http://www.renderpal.com
          my HDRI and texture collection
            Hi again,
            We've managed to reproduce it and we've added this issue to our tracking system. It seems to occur when using DR, is this the case on your end?
            yolov
            Alex Yolov
            Product Manager
            www.chaos.com
              yep....exactly....DR seems to be causing it!
                Sorry for the long delay. We managed to fix this issue and it should be working fine in the latest nightly build.
                yolov
                Alex Yolov
                Product Manager
                www.chaos.com
                  thx a lot! Unforunately i cannot test nightlies at the moment! When do you think will this fix be in the "stable" nightly releases? Or is it in there already?
                  regards
                  Oliver
                    We can port it to the stable builds, but I was hoping that you can confirm that it works correctly in the nightlies first
