Velocity pass, "max velocity last frame" not working.
  • Velocity pass, "max velocity last frame" not working.
    I'm trying to render a velocity pass but not matter what frame I'm on when I render out the velocity pass to find out what the max velocity was last frame it always says 0.
    Any idea why that would be the case?
    I'm on V-Ray for Maya version 2.25.01, revision 22441
    works fine for me in revision 22443 from Oct 18 2012
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Ok. I just created a new scene a just made a single sphere, keyframed it and the "max velocity last frame" worked fine.
      So, the new question is, what would cause that not to work in a scene? There are many things moving. Many of them are parented to other things but I don't feel like that should cause any problems with the max velocity per frame.
        Works fine for me too - do you have a scene where it does not?
          That is what I have.
          Can I send it to someone so they can take a peak?
            try delete vraySettings node and vray will make a new one, see if that helps.
            Dmitry Vinnik
            ShowReel:
              I found the problem!!!
              So, I was rendering on the farm. But due to this problem we've been having where the local computer renders buckets much darker we had unchecked the "use local machine" option.
              When I checked that back on, it seemed to work fine. I guess the farm can't calculate the Max Velocity Last frame.
              Good to know.
              Thanks!
                Ah, thanks for the pointer; will make a note to fix it.
                  Awesome.
                  You guys are the best!
