Fluid texture problem
  • Fluid texture problem
    Heya,
    I´m trying to render some fluids containers for some clouds. Everythign works fine inside of Maya, but... If I send the sequence to the farm as a vrscene the fluid only looks fine in the first frame of the sequence.
    All other frames the fluids has lost the texture information and is rendered as a simple blob
    Currently we are using this VRay Version together with the Phoenix.dll for rendering.
    [2012/Nov/28|13:10:43] V-Ray: V-Ray for Maya version 2.25.01, revision 22495 from Nov 14 2012, 01:43:12
    [2012/Nov/28|13:10:43] V-Ray: V-Ray core version is 2.00.02
    I know that it is working, because I rendered something like this before.
    A quick fix would be nice, because deadline is dropping in on Friday If there is no wuick fix, let me know so I can try an older VRay version for this scene.
    Thanks in advance Paul!
    VFX Supervisor @ www.parasol-island.com personal website www.dryzen.com latest reel http://vimeo.com/23603917
    Can you try exporting the vrscene and render on the same machine with vray.exe? To figure out if this is exporter or DR problem.
      Will check in 5 mins
        Hm, not working.
        You can download the .vrscene here www.dryzen.com/transfer/Cloudproblem.rar
        First frame everything is fine, second frame texture is missing.
        Paul
          I´ve found a sollution.
          coordinateMethod was set to grid, after changing it back to fixed it worked again *phew*
            Yes, the problem is with the coordinate method. I'm still trying to find it, but if it's working with the other method, you don't need to wait .
              No everything is fine! Just wanted to let you know
                Can you try again with the next nightly build? I think it should be fixed.
