Velocity pass broken?
  • Velocity pass broken?
    Hi!
    My velocity pass renders pure grey in the latest builds. I tested
    vray22501_22623_2013x64 and vray22501_22584_2013x64
    both don't work.
    We used vray22501_22456_2013x64 before that, and there everything works as expected.
    Ideas?
    There seems to be a problem with the velocity pass in the recent builds. Thank you for pointing it out to us, we have noted it and we'll get back to you as soon as it is fixed.
    yolov
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Hi again,
      This has been fixed in the latest nightly builds. You can give it a try and report back if anything is still not working correctly.
      yolov
      Alex Yolov
      Product Manager
      www.chaos.com
        Will try as soon as possible, thanks!
          I tested V-Ray for Maya version 2.25.01, revision 22643 from Jan 11 2013, 02:21:21. The velocity pass looks good.
          But I get an error when i start rendering in a fresh scene with only an animated cube in it:
          V-Ray error: Error loading plugin library "R:\renderfarm\vray_builds\vray22501_22643_2013x64 \maya_vray\vrayplugins\vray_Embree.dll" (-1073741795): Unknown error
          I have no embree node in the scene.
            This simply means that your CPU doesn't support AVX instructions and you won't be able to use the Embree raycayster. It won't affect your renders in any way.
            yolov
            Alex Yolov
            Product Manager
            www.chaos.com
