Multiple VRay Attributes (on shapes) ?
  • Multiple VRay Attributes (on shapes) ?
    Hi everyone,
    I am trying to set up different custom ID passes ( with the VRay User Color node plugged in ExtraTex)
    The problem is, I can't assign multiple VRay attributes on each objects, so I can't make multiple passes.
    Is there a workaround ?
    It would be perfect If I could tell the VRay User Color node to read regular Maya Attributes..
    Thank you very much,
    Raphael
    This is already done; in recent nightly builds, VRayUserColor and VRayUserScalar textures will recognize Maya attributes if they start with "vrayUserColor_" or "vrayUserScalar_" or "vrayUserString_". For example, if you add a dynamic attribute with the name vrayUserScalar_test, you can then use "test" inside a VRayUserScalar texture to access it.
      That was a very quick answer,
      Thanks vlado, I am not using nightly at the moment but I am willing to,
      Where should I ask for it ? (maybe its a silly question)
        By the way I was wondering,
        Does this work through proxy ?
          Yes, when you create the proxy the currently set user attributes are saved in the proxy and the work as expected in the renderer.
          V-Ray developer
            Only in recent nightly builds though
