Some machines render frames lighter then others...
  • Some machines render frames lighter then others...
    An odd problem, on our renderfarm some machines are rendering frames lighter then others...
    All versions of Vray are identical
    All machines have access to all files
    All machines are on the same OS/ Vray/ Maya/ Quicktime version
    On the farm, two machines out of 7 have this issue, but so far as we can tell there is no difference between the machines.
    Has anyone come across anything like this before? What else do we need to check?
    Cheers,
    Ian
    Mac OS X
    Maya 2013
    Vray 2.25.01
    Hi haich11,
    Can you tell us the V-Ray build number from the Maya ouput window (it should say V-Ray 2.25.01 revision xxxxx from... )
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Are all the machines the same? Ram /gpu/cpu etc?
      Is the memory ram set up the same way on all of them? Maybe the slower machines have less windows page file or something to do with memory.
      Or they just damaged?
      Thanks, bye.
        Do you use any GI? If yes, what are your GI settings?
