"Coverage" render element will render locally but not on our farm
  • "Coverage" render element will render locally but not on our farm
    Hi guys,
    I created a very simple scene (attached) to replicate this error. And its still happening.
    The coverage pass render element renders as expected when rendering locally to the vray frame buffer. When i send the scene to the farm. The coverage pass render element is nowhere to be seen, as if it wasnt set up to render.
    Any Ideas?
    softwares and versions:
    maya 2011
    vray 2.25.01 20120831
    Ali
    coveragePassProblem.mb.zip
    I would suggest to update your vray build/maya version as there surely lots of improvements in vray especially. For the render elements, you can check to make sure that you are rendering a render layer, where the coverage pass is enabled.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      We did a quick test with the last nightly build and it works correctly.
      Please download it and test it in your environment.
ID:	847202Click image for larger version
        Thanks Morbid and Svetlozar,
        The element is active for my render layer, so its not that.
        Systems are going to update to the latest build and then i'll test it on MAYA2011 and MAYA2013.
        Ill let you know what happens!
        Thanks again,
        Ali
          It would be a good idea to do a quick test before installing the latest Nightly.
          Nighties are not very stable builds - so it is best run a few jobs on a few machines before reinstalling it on the whole farm.
