reflect all channels not working with matte-objects
  • reflect all channels not working with matte-objects
    Hi Guys,
    could it be that "reflect all channels" does not support the MatteObject-Setting inside the VrayObjectProperties with Reflection Amount set to 1. I think the same might go for "refract all channels", right?
    We would really need that feature since we are doing a lot of water shots at the moment.
    cheers
    Oliver
    OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
    Hello ultrasonic
    Could you please give us more details what exactly do you want to achieve ?
    Currently Reflections do not affects alpha channel of the matte objects - this is a known issue and it is in our system already.
      Yes, a scene would be welcome; it's a bit hard to imagine what you need.
        scene will arrive tomorrow in the morning!!! first thing on my list!
          Here is the file..
          reflect_all_channels.mb.zip
          Please check the multimatteRE on both renderlayers....i would really like to see the Multimatte reflected even if the plane is "Matte Surface" ON inside it's vrayObjectProperties Node. It has the Reflection Amount set to 1.0
          EDIT: of course this should apply to all other channels....it's just the best to look at the MultiMatte
          does that make sense?
          cheers
          Oliver
            Thank you very much for the scene.
            It seams that this is not supported - I'll add it into our list and I'll inform you when we have it supported.
              perfect!!! thank you!
