Vrmesh from Max? UV problems
  • Vrmesh from Max? UV problems
    Edit: No problem - solved - Maya's using a different UV set, I had no idea that vrmesh supported uv sets, thanks Chaos!
    Hi there,
    I recently purchased an evermotion scene and an importing the vrmesh files into Maya. The mesh works fine and I have no problems there, but what seems to be gone is the UV mapping? Is there anything I can do to get the UV mapping back in these vrmesh files? Or is this unsuppported?
    Maya 2020/2022
    Win 10x64
    Vray 5
    hehe, what an coincidence, i had the same probl yesterday for some reason vrmesh from max didnt have uv inside maya, so i had to do the old fashion way
    max->obj->maya->vrmesh
    good luck
      As snivlem found out, you will need to reconnect the UV sets...
        yea i know, but what will happen if obj in 3dsmax has multi/sub shader?
          Not sure what you mean; the different material IDs will be listed in the proxy mesh material so that you can assign shaders to them.
            let me try and ill let u know....
              yes ur right, there is a list of all connected inputs for each sub material
              great didnt know that thing also works, well done u surprised me
              cheers
