Environment and alpha
  • Environment and alpha
    is there a way to remove the alpha from the background environment?
    Currently if you have some geometry and use the sun/sky, the sky has 0 in alpha making it invisible when open in Photoshop for instance.
    I found 2 ways to avoid that but they are a bit of a hack (add an image plane or add a sphere around my geometry and use the wrapper material to make the alpha at 1).
    So is there an option to tick somewhere in Maya to force the alpha to be at 1 (white) for the environment?
    Cheers,
    Yannick
    Portfolio: http://www.cgifocus.co.uk
    Because your sky in 360° and you want alpha with the sky, your alpha will be white on all your image (because sky is 360°).
    So, in Photoshop (or other), when you open your image, why you do not ignore alpha ?
    www.deex.info
      well depending on file format, the alpha is embedded like in png for example, and I am not sure that the sky information is actually in the file.
      I am just trying to find an easy way or maybe this need to be added.
      Cheers,
      Yannick
        Cheers,
        Yannick
        In my memory, they is an option in render global like "render separate alpha".
        Perhaps you can try this.
        www.deex.info
          I tried that and "dont save alpha channel" but both didn't work here.
            And if you use the "background" render element, and add it on Photoshop ?
            www.deex.info
              tried that as well. it sort of work but the gamma is all messed up.
                You have an "affect background" checkbox in the color mapping settings.
                www.deex.info
                  This gives me a different result.
                  It is ok, i was mainly looking to see if I haven't missed an option somewhere.
                  Thanks
