Hair flicker BF + LC
  • Hair flicker BF + LC
    Hi all, Im use BF + LC my subD 2000, thx.
    http://www.img.tv/Diego/hair_Flicker.mov
    Diego Avesani
    https://www.artstation.com/avesani
    Can you post your light cache settings?
      Hi Vlado, in GI map, we use Spherical Harmonics map.
      Thx
      Diego Avesani
        Would it be possible to attach this scene , and give us more information about the workflow you are using ?
        You have mentioned that you are using Spherical Harmonics but in the attached screen-shot , Brutte Force + Light Cache are used.
        Thank you very much in advance.
          Hi, Svetlozar, thx for feedback.
          so im did some tests, save LC.vrlmap and use mode From File, and works fine with character, but i will need try this with hair.
          Can I send scene link for download in PM? because this is a JOB file.
          Thx again
          Diego Avesani
            Since you are doing an animation, saving the light cache to a file will not work.
            However you can try increasing the size of the light cache samples a bit and turning on the "Simplify for GI" option of the hair shader.
              or just use brute force without secondary bounce.
              Dmitry Vinnik
              Silhouette Images Inc.
              ShowReel:
                Hi Vlado, thx for tips, i will do it.
                Hi Dmitry, i did it, but the secundary bounce give more beautiful results
                thx again
                Diego Avesani
