Car paint Shader Crashes Maya!
  • #16
    Hi
    yeah it happens when im running both RT and adjusting sliders in the attribute editor then trying to render....
    basically i thought it might be a scene issue. i thought i would lookdev to set up basics....
    . so i opened a new scene
    . added a sphere
    . assigned the shader
    . then started tweaking
    thats all im doing... im trying to keep it as simple as possible..
    • #17
      Does this (by any chance) happen right after you add (or unhide) some geometry using the shader AND/OR right after (re)starting the RT?
      And another important question that would help us narrow down the cause - do you remember the crash being somehow connected to the parameter called "flake map size"?
      Alex Yolov
      Product Manager
      V-Ray for Maya, Chaos Player
      www.chaos.com
      • #18
        Hi
        Yes it happens sfter im hiding/unhiding objects...... it does happen when using any of the flake parameters... but i cant get usually get past tweaking the base reflection.. it seems to crash then the most..
        really appreciate the help.
        james
        • #19
          I believe it is the swatch rendering that's causing the crash (and the fact that you have hidden geometry with the same shader). We had a related issue that was fixed, but it was probably after the 2.30 release). In any case, you can do one of two things to avoid the crash: either disable the swatch rendering (from the auto-update option of the shader's swatch or by going into Window > Rendering editors > V-Ray > render swatches) or by contacting our support@chaosgroup.com to arrange your access to the nightly builds, where this problem no longer occurs.
          I hope that helps.
          Alex Yolov
          Product Manager
          www.chaos.com
          • #20
            Thank you very much
            i will give that a try... it makes sense because i was getting a slight freeze when previewing the swatch...i will try your suggestion and post results
            James.
