V-Ray standalone & alpha applied to output
  • V-Ray standalone & alpha applied to output
    When rendering render elements out of V-Ray for Maya, each render element also gets the alpha channel applied.
    When rendering with V-Ray standalone, I'm not getting an alpha channel in any of my render elements. Is there any way to enable alpha for the render elements when rendering with V-Ray standalone?
    Best Regards,
    Fredrik
    Hmm, what file format are you saving to?
      This happens when I have .vrimg set as file format in Maya, exports as .vrscene and renders it using V-Ray standalone.
      Best Regards,
      Fredrik
        Do you convert the .vrimg file to OpenEXR afterwards?
          Yes, like this:
          Code:
          vrimg2exr.exe "X:/path/to/sceneName_camera1_renderLayer1.0001.vrimg" -half -separateFiles -compression zips -bufsize 500
          Best Regards,
          Fredrik
            I see; you are right that we don't generate alpha in that case. Will make a note to add an option for it.
              Ah, that would be great. Thank you.
              Best Regards,
              Fredrik
