vray slave segmentation fault port 20207
  • vray slave segmentation fault port 20207
    I currently have a mac (mtn lion) and a pc (win 7), been rendering quite happily for over a year with the pc as the main workstation and the mac acting a slave .
    all of a sudden the slave isn't working... I do the usual, set up the slave in a terminal and it reports :-
    "Entering server mode - waiting for render requests on port 20207. Press Ctrl+C to exit."
    I hit render on the main workstation and the slave seems to be fine but then reports a segmentation error at the end. Ive created a simple scene to check and get the same fault ....
    Loading plugins from "/Applications/Autodesk/maya2013/vray/vrayplugins/libvray_*.so"
    [2013/Aug/21|09:22:36] 102 plugin(s) loaded successfully
    [2013/Aug/21|09:22:36] Finished loading plugins.
    [2013/Aug/21|09:22:36] Entering server mode - waiting for render requests on port 20207. Press Ctrl+C to exit.
    [2013/Aug/21|09:24:19] Starting DR session from 169.xxx.xxx.59
    [2013/Aug/21|09:24:19] Receiving DR scene from 169.xxx.xxx.59
    [2013/Aug/21|09:24:20] Reading scene file "/tmp/vrscene.txt"
    [2013/Aug/21|09:24:20] /tmp/vrscene.txt: done [ 0h 0m 0.1s]
    [2013/Aug/21|09:24:20] Scene file parsed successfully in 0.1 s.
    [2013/Aug/21|09:24:20] Scene created successfully.
    [2013/Aug/21|09:24:20] Objects in scene: 845
    [2013/Aug/21|09:24:20] Starting render sequence.
    [2013/Aug/21|09:24:20] Preparing renderer...
    /Applications/ChaosGroup/V-Ray/Maya2013-x64/bin/vrayslave: line 3: 684 Segmentation fault: 11 /Applications/Autodesk/maya2013/vray/bin/vray.bin $* -server -portNumber=20207
    please help
    thanks guys
    ignuf
    just wondering if there's a list of fault codes published anywhere ?
      Which V-Ray build is that? Do you have a crash dump?
        Also, did you update your Mac recently?
          Hi Vlado,
          the installation file is "vray_adv_23001_maya2013_x64.exe" - version 2.30.01 from may 11 2012 - I'm not sure re the "crash dump" so I guess I don't have one setup... how can I check ?
          also not updated the mac recently .
          thanks for getting back
          regards
          ignuf
            Hi Again,
            ok i'm not sure if this helped in some random way but I went into Autodesk/maya2013/vray/bin and in a terminal entered setvrlservice -server1="my pc's ip address" .... this was in an attempt to get the mac to use the license on the pc and render out using vray standalone..... i haven't managed to get the standalone woking as yet but now it seems the vray slave is working again !!
              Odd, but I'm glad things are working now
                @ignuf On the Mac, can you check which version of the WIBU dongle drivers you have installed?
                /Emil
                V-Ray for Maya developer
