disable output when using vrayCreateProxy
  • disable output when using vrayCreateProxy
    Hi
    I was wondering if it's possible to disable the output vray creates when using the vrayCreateProxy mel command?
    I have 5000+ animated objects that i export into a single .vrmesh file and I suspect it slows things down as well as cluttering my logfiles (i'm using it in mayabatch mode.)... Thought there may be a hidden switch for it somewhere?
    Setting the message level in render globals seems to have no effect on this command.
    David Lessél
    Thanks for the pointer; will see what can be done about it.
      Sounds great, thanks Vlado!
      David Lessél
