vray proxy bug?
  • vray proxy bug?
    We recieved some cad car models and when turning them into vray proxies, everything worked fine except for the cars registration plates. If I turn both the back and the front plate into a combined proxy, the front plate can't display its shader correctly (it seems to be something with the uv). If I turn them into seperate proxies, everything works as expected. We've tried every trick in the book to get them working, merging verts, recreating uvs, export as obj and import, etc but it still does not work when the two meshes are combined into one proxy.
    Any idea what the problem is?
    I've attached a scene with three groups: the original geo, a combined proxy and seperate proxies. If you render the combined one you'll noticed that the front plate gets pure pink.
    One of them probably has reversed normals.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Like I said, we've tried most standard things, including checking normals, but good with more suggestions. Our main brain here thought it might be a vray proxy bug, that's why I put the scene here.
        It seems that the cause for the problem is that the two objects have uv sets named differently.
        The result of the export is a proxy with two uv sets, but not all faces have uvs in both sets.
        I've modified the uv sets names on both objects and the exported proxy rendered fine.
        You can debug such issues using the "ply2vrmesh -info path/to/file" command.
        See an example for your file:
        Code:
        $ ply2vrmesh -info /tmp/vrayProxyBug/regplatesBoth.vrmesh
        Converter of .ply .obj .bin .geo and .abc files to .vrmesh files
        Copyright (C) 2003-2013 by Chaos Group Ltd. All rights reserved.
        Build from Oct  3 2013
        Information for "/tmp/vrayProxyBug/regplatesBoth.vrmesh"
          Number of frames: 1
          Number of voxels: 3
          Reading voxels... done
          Total number of triangles: 2,064
          Preview triangles: 500
          Channels:
            Vertices
            Faces
            Vertex normals
            Normals faces
            Face info
            Maya info channel (data is valid)
            Number of texture channels: 2
            Texture channels list: 0 - 'dressing:uvw:0_428', 1 - 'dressing:uvw:0_429'
          Bounding box: [-93.990, 28.337, -26.000] - [358.621, 42.642, 26.000]
            UV sets: 2 ('dressing:uvw:0_428', 'dressing:uvw:0_429')
            Color sets: 0
            Shader sets: 2 ('regBackVM', 'regFrontVM')
        Probably it is a good idea to run a script that unifies the names of the uvsets for all meshes that have single uvset.
        V-Ray developer
          It works fine if you combine both meshes before Proxy-export (Mesh>Combine).
          Please view the attached file ( you have to restore proxy path ) 498_Proxy_Issue.zip
