Reflection pass empty with wrapper?
  • Reflection pass empty with wrapper?
    I'm noticing that the reflection pass is empty where a wrapper material is applied, even though the reflection on the wrapper material is clearly visible in the beauty.
    Steps to reproduce
    1) make a sphere on a plane
    2) make the plane reflective so you can see the sphere in it
    3) put a wrapper material on the plane (reflective material in the base, matte surface on)
    4) add a reflection render element
    5) Render. The reflection is there on the plane in the beauty, but not in the reflection pass.
    Is this a bug, or am I missing something?
    thanks!
    I see that we have this already added to our "to do" list.
    Actually I'm not sure if its a bug or new feature implementation, but it should work.
    Anyway thank you for your report.
    Tashko Zashev | chaos.com
      Hi Tashko,
      Do you have any updates on this issue?
      Artists here just faced this problem and we've found this related thread.
      Is it something planned to be fixed in 3.0? Is there a nightly build which addresses this issue?
      Thanks,
      Giovani Meneghel
        Unfortunately not yet, I will check if we could rise up the priority of this case.
