Hello All,
I am seeing the same issue via Deadline, I can batch render locally, via Maya gui and commandline, but running the same thing via deadline throws up a an error exactly as you state, unable to dynamically load the plugin.
I have confirmed my ENV VAR's but can share if needed, but they all seem to be set properly.
Maya Gui Vray seems to work fine.
Again I can launch locally with a install of Maya on my c:\ drive and render via Maya gui (batch and render.exe)
I can launch the .exe sitting on the network share and render a vray scene, all the plugins load fine.
When I submit the scene to deadline, the nodes bomb out with this error.
Any Ideas?
Any help would be greatly appreciated.
Any Ideas?
Code:
0: STDOUT: Error: line 1: Unable to dynamically load : S:/resources/_Additional_Plugins/MAYA/Plugins/VRAY2.30/plug-ins/vrayformaya.mll 0: STDOUT: The specified procedure could not be found. ..... ..... 0: STDOUT: Error: file: S:/resources/_Additional_Plugins/MAYA/Plugins/VRAY2.30/scripts/vrayRegisterRenderer.mel line 304: The renderer vray is not registered yet. Ive checked all my paths but can share if needed.
