Projection node into VRayMtl Refraction Color
  • Projection node into VRayMtl Refraction Color
    Hi, I tried searching but it seems that this isn't reported yet?
    A projection node plugged into refraction color doesn't seem to work. It is ignored.
    I'm using a ramp to fade out refraction.
    [2013/Nov/27|11:53:39] V-Ray: V-Ray for Maya version 2.45.01, revision 23781 from Oct 30 2013, 06:03:29
    Maya 2020/2022
    Win 10x64
    Vray 5
    Well as a workaround I have tried this approach (blendColors.outR > refractionColorAmount). Seems to work
    Maya 2020/2022
    Win 10x64
    Vray 5
      It seams it works fine here with the last official Vray 2.40.01. Would it be possible to check the following setup - I've tried to replicate what you have on your side:
      Ramp texture assigned into Projection node which is plugged into Refraction color slot of VrayMtl - you can see that if I reverse the RampColors I got different results.
      SceneFile=>refrProjec.zip
        Thank you Svetlozar, I can see the difference between our scenes is the mode of the projection node. I had mine set to triplanar - however this was the incorrect choice for my type of projection so I was getting results I didn't think should happen. So entirely my fault. Rookie error!
        Thanks again for posting the scene as it has been very helpful.
        Maya 2020/2022
        Win 10x64
        Vray 5
