Z-Depth Render Element Problems
  • Z-Depth Render Element Problems
    we upgraded to Maya2014 with vray build: vray_adv_24501_maya2014_x64_23873
    I encountered a problem with the zdepth render element, which doesn´t work like it did before.
    See attached pictures for details.
    Thanks in advance
    Could you share that you used? Could you expand a bit on what do you expect as correct here for your settings in each zdepth channel?
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      I´ll try to explain what I would expect from the zdepth channel in the images I posted before.
      The scene just consists of some cubes WITHOUT any background object, image or something else
      For the render element I used the mentioned values for the Depth.
      Depth Clamp is ON and Filtering OFF
      1st image: Depth Black 00 || Depth White 30
      The Background should be white
      2nd image: Depth Black 10 || Depth White 30
      Looks OK
      3rd image: Depth Black 30 || Depth White 00
      Background should be black
      4th image: Depth Black 30 || Depth White 10
      5th image explains what it should look like with Depth Black 30 || Depth White 00
      When using 0 neither for black or white something gets flipped internally I guess?
      I hope you understand what I mean.
      Masking the zdepth pass via the alpha from the Beauty in Compositing won´t work due to the fact that we don´t want to have anti-aliaising on the edges of the clipped objects.
        Yes, thank you for the explanation. I thought that might be it, but I wanted to make sure. Seems like a bug. I'll try and get back to you with more info on when we can have this fixed.
        Alex Yolov
        Product Manager
        www.chaos.com
          Hi there,
          Was there a solution to this? as it's causing me problems on a lot of jobs.
          Regards
          Keith
          KEITH ROGERS
          Learn the rules like a pro so you can break them as an artist.
          http://www.3layersofparallax.com/
