Path variable? "The specified procedure could not be found"
  • Path variable? "The specified procedure could not be found"
    I have Maya 2014 and 2013 running on windows 7 here. V-ray 2.40 is working in Maya 2014. Then I installed V-ray 2.40 for Maya 2013 and the plugin does not load.
    // Error: line 1: Unable to dynamically load : C:/Program Files/Autodesk/Maya2013/vray/plug-ins/vrayformaya.mll
    Det går inte att hitta den angivna proceduren.
    // Error: line 1: Det går inte att hitta den angivna proceduren.
    (vrayformaya) //
    I have search this forum and found this:
    http://forums.chaosgroup.com/showthr...namically+load
    But where do I change the PATH VARIABLE?
    Help appreciated
    Thx
    Please check your V-ray environment variable paths for the current Maya version.
    You can find some instructions here:
    http://help.chaosgroup.com/vray/help...l_from_dir.htm
    Should be something like this
    If you still have problems to run the V-Ray plugin for Maya 2013, send us an email to support@chaosgroup.com and we will provide you with further assistance.
    Tashko Zashev | chaos.com
