warning when .tx texture files
  • warning when .tx texture files
    I converted all my png/jpg textures to .tx files using the nMakeTx script from CreativeCrash http://www.creativecrash.com/maya/sc...nold-renderman
    The script is designed for the maketx.exe that comes with Arnold, but I assume .tx is a universal format and V-ray can use these same files?
    When I render my scene with the .tx files, it renders without a problem and all my textures appear...
    However in the Output window I get the following warnings multiple times for each texture:
    TIFFReadDirectory: Warning, path/texture_name.tx: unknown field with tag 317 (0x13d) encountered.
    path/texture_name.tx: Can not read scanlines from a tiled image.
    ERROR, Cannot read scanline 1023; No error
    path/texture_name.tx is an example abbreviation I replace of the actual path and name because it was long.
    Should I be worried about these warnings?
    Are these warnings written by V-Ray when rendering? I think the Maya swatch renderer produces them when attempting to draw the swatch for the File node - if this is the case, you don't need to worry about them.
      .tx is a mipmapped tiff, so in some cases a certain compression may be used by maketx.exe which is not supported by either a renderer or software. You may need to specify with maketx which compression to use.
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
        You're right. Maya writes the warnings when I open the hypershade and maya tries to generate preview swatches.
        Thanks
          Very well then. Perhaps you can drop a line to Autodesk to fix this...
