Segmentation fault: 11 error
  • Segmentation fault: 11 error
    "/Applications/Autodesk/maya2014/vray/bin/vray: line 3: 1005 Segmentation fault: 11 /Applications/Autodesk/maya2014/vray/bin/vray.bin -portNumber=20207 $*" What does this error mean?
    plugin version: 2.40.01 (maya)
    osx: 10.8.5
    please help
    That V-Ray standalone has crashed.
    Can you tell us what have you done to make it crash?
    V-Ray developer
      We actually had this just recently (2.40.01). It seemed to happen because there was a UV Chooser node attached to some geometry which were pointing to a UV map that did not exist.
      Best Regards,
      Fredrik
        Fredrik Averpil: do you have a scene we can use to reproduce the problem?
        V-Ray developer
          I simplified the scene down to the supposedly errorous parts: segfault.zip
          No textures are needed. Render this with DR enabled in V-Ray 2.40.01 in Maya 2014.
          When I do this here some DR slaves get the segmentation fault - but not all of them. It seems it's more prone to crash on Linux than on Windows, but it seems a little random.
          Network showing the uvChooser connected:
          Showing the amount of DR slaves, the ones in red crashed and is a mix of Windows and Linux machines:
          Best Regards,
          Fredrik
            Thank you for the scene. We were able to reproduce the issue and we will try to fix it.
            V-Ray developer
              I know you will!
              Best Regards,
              Fredrik
                hi,
                did anything come to light on the segmentation error ? I'm currently having a similar issue rendering a scene with DR, it starts off ok in that the render slave starts up but then gets a segmentation error and exits . ( the render on the main machine continues , but the slave does not contribute to the render)
                  I think the original issue was fixed. However yours may be something else - if you can get us a reproducible case, it will be very very helpful.
