Python scene access list
  • Python scene access list
    Hi everybody,
    I'm new in this forum so let me introduce myself.
    My name is Maxime, I'm Lighting TD at Supamonks .
    We're currently experimenting on Vray Python Access but we've encountered some difficulties with lists... I've sent an e-mail to chaos group support but I haven't got feedback regarding this point.
    We've tried to set lists (like colors in a ramp) with the post translate script but it returns the following error :
    def postTranslateScript():
    import vray.utils
    ramp = vray.utils.findByName('ramp1')[0]
    if 0:
    colors = ramp.get('colors')
    colors.pop()
    # This line will warm: // Warning: line 1: Invalid value given for parameter "colors" in plugin "ramp1". //
    ramp.set('colors', colors)
    else:
    # This line will warm two: // Warning: line 1: Invalid value given for parameter "colors" in plugin "ramp1". //
    vray.utils.pluginmodifier._setParam(ramp._name, 'colors', (12, ['ramp1_color_0', 'ramp1_color_1']))
    So, it seems that lists cannot be used in python scene access...
    Am I right ?
    Thanks,
    Max
    We do support lists in general; can you tell me which V-Ray version you are using?
      Oh ! Sorry, I forgot to mention it ^^'
      We're using vray 2.40 with maya 2012.
      Thanks,
      Max
        It is a bug with ramp in Python access ^^
        www.deex.info
          Yes, the Python script can't export list of textures. Will fix this.
          V-Ray/PhoenixFD for Maya developer
            Ok, thank you all for your answers !
            Would you have an idea of when we could expect this fix ?
              It will be in the next nightly. But this means 2.45.
                We have access to nightlies version so it's a really great news !!
                I may have some further questions regarding python scene access, can I ask these questions here ?
                For example, we would like to kill a render process using python.
                Is there a way to do it ?
                  When do you want to kill it? In some of the callbacks or from the script editor while rendering?
                    Actually, we would like to be able to stop it with the post translate python script in case there's something wrong.
                      I thought that there is a standard way to send "abort" signal to the renderer (like clicking Esc), but it seems there isn't. We can extend the vrend command with something like "-abort". Currently it can abort only IPR rendering.
                        It could be great !
                        So, this mean that the vrend command is callable during the execution of python post translate script ?
                        And, if you extend the vrend command would it be possible to add a flag to translate only selected objects ?
                          vrend can be executed in the post translate, but with limited functionality since you are already rendering. It's ok to abort rendering. Will be in the next nightly.
                          There is a way to render and translate only selected objects, but it's not very convinient:
                          optionVar -iv renderViewRenderSelectedObj 1;
                          And you must not forget to restore it to 0. This can be set before rendering using a script or a prerender MEL. And restored with a postrender MEL.
                            It would be very great if we can have something like : vrend -selectedObjects MyList
                            Premel and PostMel are a hell in production (and it can be very dangerous. Imagine if we have an error (crash, network...) during rendering, we will break the optionVar of the user).
                            www.deex.info
                            • #15
                              I totally agree with that ! ^^
