single sided leaf
  • single sided leaf
    This is not rendering as I would have thought it would.
    I've had no issues in the past so not sure why it's happening now.
    The image show a leaf rendered with normal facing out and the second leaf facing away.
    I really dont understand what is happening with this render so if you could shed some light that would be great!
    Thanks for any help.
    leaf.mb.zipClick image for larger version
    I managed to reproduce it and it's not working as it should. We will look into it.
    Thank you,
    Georgi Zhekov
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Hi Georgi, has this been fixed in any other beta release?
      Many thanks
      S
        Unfortunately the bug still persists. It happens when you use an image without an alpha channel, mapped in the opacity slot, so if you use an image with alpha, it will render as it should.
        Thank you,
        Georgi Zhekov
        Georgi Zhekov
        Chaos
          Hi Georgi.
          That interesting but the sample I supplied did have alpha texture mapped to the opacity slot! yet it still happens?
            Yes, you have mapped texture in png format, but its alpha channel is empty and this is the reason it's not working.
            Thank you,
            Georgi Zhekov
            Georgi Zhekov
            Chaos
              Right I see! ok thanks for clearing that up, at least there's a work around.
              Thank you
