img2tiledexr question
  • img2tiledexr question
    Hello!
    We have two questions about img2tiledexr:
    1. If we don't have an alpha in the input image, img2tiledexr creates a white alpha. Shouldn't it respect the incoming channels? I've tried this with an incoming exr image.
    2. Does img2tiledexr set the header "pixelAspectRatio" slightly wrong?
    If we have a 1920*1080 texture converted to tiled, it sets the pixelAspectRatio to 1.777778. I think this header is for non-square pixel aspect ratio not for resolution aspect ratio. So when you read the 1920*1080 converted texture into Nuke for example, you get a squeezed image. So pixel aspect ratio should be 1, in most cases (unless incoming image as non square pixels).
    Cheers!
    Thanks for the pointers, these seem like bugs and we'll fix them.
      These two bugs are fixed in the latest nightly builds.
      Asen
        Perfect, thanks!
