Segmentation Fault when doing IPR
  • Segmentation Fault when doing IPR
    In VRay 3.0 Beta for Maya (Mac), everytime I do an IPR (VFB disabled), a terminal session is opening and is crashing with a Segmentation Fault:
    [2014/May/27|16:20:53] SD triangles: 0
    [2014/May/27|16:20:53] MB triangles: 0
    [2014/May/27|16:20:53] Static primitives: 0
    [2014/May/27|16:20:53] Moving primitives: 0
    [2014/May/27|16:20:53] Infinite primitives: 0
    [2014/May/27|16:20:53] Static hair segments: 0
    [2014/May/27|16:20:53] Moving hair segments: 0
    /Applications/Autodesk/maya2014/vray/bin/vray: line 5: 2370 Segmentation fault: 11 /Applications/Autodesk/maya2014/vray/bin/vray.bin -portNumber=20207 $*
    logout
    Hence I can't do any IPR (I link this to the last nightly upgrade I did a coupl eof weeks ago), but that may be coincidence.
    Thanks for assistance !
    What is the OSX version? What is the Maya version? What is the exact V-Ray version?
    Does it happen with a simple scene?
    Are you running RT-CPU or RT-GPU?
    V-Ray developer
      Thanks for the quick answer. After having done the test with a simple scene, the issue does not occur.
      Will try to understand what's wrong with my current scene.
      (It's Maya 2014, CPU RT)
        If you can't find the issue then you can send the scene to our support at support@chaosgroup.com for further investigation.
        V-Ray developer
