Anyone else having issues with swatches in Maya 2015ext1 with node editor?
  • Anyone else having issues with swatches in Maya 2015ext1 with node editor?
    They seem to fail to render all the time. I'm not sure if it's an Autodesk bug or not but I was curious if it is failing for anyone else.
    The swatches will just be blank/grey and no amount of playing with the node will get the swatch to update. file textures, vraymtls, noise, lamberts, phongs - everything. Sometimes it'll fix itself and the swatches will render again but it doesn't last long.
    [2014/Oct/11|17:04:29] V-Ray: V-Ray for Maya version 2.45.01, revision 24958 from Sep 11 2014, 08:12:58
    Maya 2015x64Ext1
    Maya 2020/2022
    Win 10x64
    Vray 5
    You mean that even standard shading nodes fail to show the swatch (i.e. Ramp, Blinn, Lambert etc)?
      Hi Vlado, now that you mention in - it did happen a few times today and it also affected ramp, blinn) as well as VRayMtl - so I suppose this is not a V-Ray issue. It's really odd too because it happens both on Work and Home computer (they are very different setups). I'll log it with Autodesk
      Maya 2020/2022
      Win 10x64
      Vray 5
        Ok then, let me know what happens.
