ImportError: No module named asgvisInit
  • ImportError: No module named asgvisInit
    I've installed Maya 2015 Extension 1 SP5 as well as V-Ray 3.0 for Maya on the network (so called "Thin Client"). And perhaps this is why I cannot launch the vrmat editor (from within the vrmatMtl attribute editor; button "Show VRMat Editor").
    When I click that button I get:
    Code:
    # Traceback (most recent call last):
    #   File "<string>", line 1, in <module>
    # ImportError: No module named asgvisInit
    So, I thought that this would be fairly easy to fix. I'd just have to locate "asgvisInit" and append its location to sys.path (PYTHONPATH) before launching Maya. But I can't find this anywhere in the V-Ray 3 installation. I installed V-Ray 3 using the ZIP file bundles.
    Do you know where it could be located?
    Last edited by Fredrik Averpil; 14-11-2014, 08:01 AM. Reason: Added some more details
    Best Regards,
    Fredrik
    Have you found the asgvisInit.py file? It should be located in the vray/scripts/ folder.
    What is the exact version you're trying to use and what kind of package are you using (zip or executable) to install V-Ray?
    Can you try if the python post translate scripts work?
    /Teodor
    V-Ray developer
      Hi Teodor,
      I installed from zip, the V-Ray 3.00.01 version from the download area for Maya 2015 64-bit.
      No I can't find the asgvisInit.py file in the /maya_vray/scripts forlder. Could it be missing from the zip?
      Best Regards,
      Fredrik
        Hm.
        There seems to be a pretty big discrepancy between the 3.00.01 release and the latest stable nightly...
        This is from the stable build 25208 zip, maya_vray/scripts/vray:
        Code:
        2014-11-14  09:44    <DIR>          .
        2014-11-14  09:44    <DIR>          ..
        2014-11-07  09:10             6*970 acolor.py
        2014-11-14  09:44    <DIR>          ASGVIS
        2014-11-07  09:10            12*778 asgvisInit.py
        2014-11-07  09:10             9*366 color.py
        2014-11-07  09:10               274 helperfunctions.py
        2014-11-07  09:10             3*474 hostvrayplugman.py
        2014-11-07  09:10           107*000 MaterialPreviewScene.xml
        2014-11-07  09:10            11*623 matrix.py
        2014-11-07  09:10             6*637 mayahostapp.py
        2014-11-07  09:10             6*422 plugin.py
        2014-11-07  09:10           243*712 pluginmodifier.pyd
        2014-11-07  09:10             2*778 pluginoutput.py
        2014-11-07  09:10         1*257*472 PyBin2Xml.pyd
        2014-11-07  09:10            63*994 pyCallbacks.py
        2014-11-07  09:10             3*282 PyProcMsg.py
        2014-11-14  09:44    <DIR>          PyQt4
        2014-11-07  09:10         7*999*488 PyVRay.pyd
        2014-11-07  09:10            75*776 sip.pyd
        2014-11-07  09:10            64*364 TexturePreviewScene.xml
        2014-11-07  09:10               194 toolTipStyle.css
        2014-11-07  09:10             6*760 transform.py
        2014-11-07  09:10             4*271 utils.py
        2014-11-07  09:10             8*704 vector.py
        2014-11-07  09:10             2*751 VRayPluginChanges.xml
        2014-11-07  09:10           797*645 VRayPlugins.xml
        2014-11-07  09:10             1*539 vraytype.py
        2014-11-07  09:10             7*132 xgen.py
        2014-11-07  09:10             6*983 xgenVRayUI.py
        2014-11-07  09:10               255 __init__.py
        and this is from the official 3.00.01 zip release, maya_vray/scripts/vray:
        Code:
        2014-11-13  11:42    <DIR>          .
        2014-11-13  11:42    <DIR>          ..
        2014-10-16  23:41             6*970 acolor.py
        2014-10-16  23:41             9*366 color.py
        2014-10-16  23:41               274 helperfunctions.py
        2014-10-16  23:41            11*623 matrix.py
        2014-10-16  23:41             6*422 plugin.py
        2014-10-16  23:41           243*712 pluginmodifier.pyd
        2014-10-16  23:41             2*778 pluginoutput.py
        2014-10-16  23:41             6*760 transform.py
        2014-10-16  23:41             4*271 utils.py
        2014-10-16  23:41             8*704 vector.py
        2014-10-16  23:41             1*539 vraytype.py
        2014-10-16  23:41             7*132 xgen.py
        2014-10-16  23:41             6*983 xgenVRayUI.py
        2014-10-16  23:41               255 __init__.py
        EDIT: I can confirm that I can successfully load the VRMat editor when running the stable nightly. So I'm just going to remove the official build alltogether here.
        Best Regards,
        Fredrik
          Yes, it seems there are problems with the zip installer.
          A temporary work around is to use the exe installer and tell it to install in a custom location.
          Then you can apply the same procedure as using the zip installer.
          Thanks for reporting it and sorry for the inconvenience.
          V-Ray developer
            Ok, thanks. I think we will be fine with the stable build 25208 so I'll just use that.
            Best Regards,
            Fredrik
