vrmesh import commands
  • vrmesh import commands
    Is there some docs. for mel-scripts/python commands for importing vrmesh to Maya ?
    I want to import multiple vrmesh-es by mel/python into Maya.
    thx for reply
    Rasto
    Ok, i found it as mel: vrayCreateProxyExisting(name,file,objectPath)
      Sorry for the late reply; I see you found a solution already. Let us know if there are other questions.
        Hi Vlado,
        is there some docs. for this commands ?
        I found another command, but i don't understand second param. vrayProxyFileIsReadable(file,???);
        What this command doing ? Checking if vrmesh file have correct content ? Is it checking only header or reading full content of vrmesh ?
        Rasto
          Nope, these are all internal functions. You can use them, but is at your own risk and they might change in newer versions.
          What is the purpose you want to use this function? The parameter is a name of a textCtrl, which will be filled with same text.
          V-Ray developer
            I have problems with vrmesh-es in this post.
            I wanted to check if file is correct and readable vrmesh.
            btw. thx for reply.
            Rasto
              You can use the tool "ply2vrmesh -info <yourfile>" to do some minimal check if the vrmesh file is intact.
              V-Ray developer
                It's not working for me (this command run out of memory), because i have problem with incorrect meshes from ply2vrmesh.
                Now i am checking with script if vrmesh file is smaller than 20 bits and this type of checking is working.
