I've been running into an issue with VrayLightIES paired with an IES profile from Kino-Flo. Basically, when the lights show up in a glossy reflection, they're very grainy unless I up the samples very high. If I use a vray rectangle light or dome light/exr map it works fine. I've messed around with the sampler settings quite a bit. The resolution on the lights themselves don't seem to have much of an effect (upped them from 8 to 64). My DMC is 1 and 12, with adaptive threshold 0.010. Is this an expected result? or am I doing something wrong?
Lowering the threshold/upping the max samples does get around the problem, but at a huge render time cost.
